johnforristal
I have a strange problem with our roof on our California. When you raise the roof it gets 95% to the top and just stops. No noise of the motor trying to raise further. Just stops. When you try to lower the roof. Nothing happens. No noise. Just nothing. If you remove the control panel and undo the screw on the pump until the roof starts to drop then tighten the screw again, to release the pressure, it will come down using the motor. I have replaced the roof hydraulics control unit, no difference. I have sent the pump off to be "refurbished", no difference. There are only those two components really to the system. Everything works (kind of) but yet if you raise the roof to the maximum it will go to, You are stuck. Please has anyone experienced a similar problem which has been solved?
