Christine Kirk
- Messages
- 197
a puncture on our 8 month old ocean gave us a long delay as we couldn't get the wheel off the hub!
Living in rural Yorkshire we had the spare wheel option so as to be able to get back on the road with minimal fuss if we had a puncture.
Last Monday, in the dark, in the rain it happened; a total flat, sods law, so we waited until daylight and went to sort the wheels. No problem getting everything sorted until trying to remove the alloy wheel from the hub. No amount of reasonable force would release it; it was on the jack and on a gravel surface!
VW Assist called and arrived a couple of hours later. The wheel was duly removed using a large rubber mallet and a lot of force.
Corrosion between the steel hub and alloy wheel had bonded the two together. The technician said that it is common and can be a real problem if the surfaces are not treated with a release compound such as "copper slip". also the spare wheel cradle support bolts require grease as they easily seize due to the exposure to the elements. Is this a preventive item done at servicing?
Might be a prep job that better service departments would do routinely in the pre delivery servicing; certainly JCT 600 Sheffield didn't do this to our Ocean before we collected it last February, as a result we spent a morning getting the wheel off and back on the road not 20minutes it should have been.
that's life eh! but have yours attended would be my recommendation.
