DM
Has anyone else experienced this. I have a 2016 MY Ocean with climatic Air Con. The rear air-con seems to have a mind of it's own. It is turned off in the rear with the vents closed. The 'rear' button is off on the dashboard control. Every now and again the rear AC fan starts blowing at full pelt. It cannot be turned off in the back or by using the 'rear' button on the dashboard.
I have found that playing around with the controls does eventually turn it off. I think the sequence that works is as follows. Turn on 'rear's the dash. turn auto off by manually rotating the fan speed knob. Turn the fan right down. Turn 'rear' off on the dash. Re-enable auto.
Is this a fault or a bug? Should I ask it to be investigated? - it is not easy to re-produce at will. It happened about 5 times over a two week period using the cali every day. I'm a bit cautious about reporting it as I currently have a 50/50 record of the dealer making things worse when trying to fix things!
