So do we, our rear shelf is a shelf not a metal thingyWe also use the higher position for giving a bit of extra space under the shelf while travelling...
I assume you meanbthat it’s slightly higher at your head end (against the tail gate)We have our shelf at the rear on the highest setting so it's more comfortable whilst sleeping
Hi Birty. Yep as I said, at the rearI assume you meanbthat it’s slightly higher at your head end (against the tail gate)
I would assume the same? Flat is best unless for health reasons? Will try it though !Does that not make it more uncomfortable...?
I presumed a flatter bed is best?
25 is just a plastic tube insteted in the metal hole I think. 28 is the screw to hold 23 into place?Hi all
One of the sockets for fitting the rear shelf/bed extension is broken off a bit.
I would like to replace these. How is this attached? Screwed in or stuck?
Looks like number 25 Part number 7H7068135A
Here in belgium they come at the cost of .....Yes it's the plastic bushes I need
Ouch! Maybe I'll make ones that don't break from some silicon tubingHere in belgium they come at the cost of .....
€11
