Rear bench movement / travel
Strong
Strong
Chris & Karen
Langport, Somerset
Hi all
Just a quickie. Anybody know how I get the seat further back than this ...
Cheers,
Chris
There probaly be a stop in one of the two rails.
How to remove those stops is written somwhere on the forum....
Well you live and learn. I had not spotted the difference between the rails in the Ocean and Beach. The Beach ones extend all the way to back of the boot...
Yeah, slide the seat a bit more forward
Thén put a screw driver In the grove and run it towards the seat , on one, prob the off side, you will hit something,
Unscrew it and slide it backwards
Sorted
Well the SE/Ocean seats cannot fold forward so I presume there is no need to have the rails further back as due to the seat back position you wouldn't be able to shut the tailgate.
I should have clarified that on the Beach the outer rails go right to the rear, probably more to do with the multiflex board mounting. The middle two are about the same distance as the Ocean.
