Kelly & Rob
We're hoping someone may be able to help! We are trying to find the floor space dimensions for when the rear seat is fully forward. Does anyone know? Thank you in advance
We don't pick it up for a couple more weeks. It's with the seat pushed forward to the furthest point. Any help appreciated.Any reason you can't measure it?
And is this with the seat at the stop or with the stop removed?
No - but from memory the runner stops about 12 inches. Thank you for any help you can giveDo you still need leg room for those on the bench seat.
Sent from my SM-G930F using Tapatalk
Remember if the Front Stop is removed and the seat is fully forward then it may NOT be fully secured.No - but from memory the runner stops about 12 inches. Thank you for any help you can give
That's helpful - thank youJust gone out and measured with the stop taken out. I was sure to avoid the removal point in the rails and put the bench seat fully forward. It measures at 1.65 metres to from the tool kit in the rear bench to the end of boot up to the point of the seal plastic. Hope that helps.
Thank you.Remember if the Front Stop is removed and the seat is fully forward then it may NOT be fully secured.
