Rear wiper and heater 6.1 coast.
Wilso122_t61-coast
Wilso122_t61-coast
Uk
T6.1 Coast 150
Hi there.
Hoping someone can help. MY21 T6.1 coast RHD. The rear wiper and screen heater are not working. The manual is useless with no fuse layout
Took a look in the vip section and one says 15a the other 10a and in the layout pictures it looks like the fuse is not even in the van, looking at the pictures.
Looking at the fuses below right of the steering wheel and totally lost.
Anyone know where it should be and what amp.
Thanks a lot.
Hi there.
Thanks a lot.
List here for VIP member download
thanks to @Loz
And image with numbers
Think fuse 57 for rear wiper and fuse 20 heated screen (controlled by fused relay 30 amp due to current draw)
Think your dash cam fuse holder is cover fuse 57 15 amp for the rear wiper.
If this is a recent fit may not be correctly seated?
Brilliant thanks for the help. Will give that a go tomorrow.
Wondered what that was, previous owners must have had it installed so will pull that and put a 15a in and check the 30a for rear heated screen.
Thanks to Loz as well for the uploads.
Just tread carefully, the “piggy back” fuse holder may just be obscuring the 15 amp rear wiper fuse underneath. Remove the piggy back and see what you have.
If there is a 15 amp underneath then check if this is blown before doing any changing fuses in the piggy back.
From memory the dash cam fuse is 2 amp and the other fuse will be what was in the holder before the piggy back introduced.
I have re orientated your image to match @Loz image and ringed the 30 amp fuse that you have which wasn’t present in Loz’s image (presumably because the vehicle didn’t have a heated screen )
Not sure in your post if you are referring to a heated front screen or a heated rear screen.
Given the different circuits and the separation of the fuses in the fuse box, I am not optimistic that both fuses would have gone together unless something has shorted the cables to both items (if you are dealing with rear wiper and heated rear window) in the umbilical cord that runs from the vehicle body to the top left of the tailgate.
(Sorry re read your response and you state rear screen, so is possible that something has damaged the supply cables to both items in the tailgate area/umbilical cord causing a short and both fuses to go)
Hope this helps
thanks a lot will check piggy back carefully.
Hoping it is fuse related as the rear washer works fine unless that is on a different loom / canbus
If not fuses will have to visit the dealer.
thanks to @Loz
All sorted, thanks a million.
The dashcam piggy back was in the wrong slot so removed and 15a direct in correct place, might think about a dashcam later.
The rear heater, who knows, removed fuse to check put back in and all working. Maybe just not seated correctly.
Thanks again.
Thanks again.
Excellent news and thank you for prompt feedback on a satisfactory outcome
