andyinluton
- Messages
- 7,739
- Vehicle
- T6.1 Ocean 204 4 motion
I've just been outside to measure mine - Im at 204cm to top of awning & the roofs a bit higher than that. Its never had any thing in the back yet & I would expect it to settle a fair bit once it has had some load in there.As someone mentioned, tyres might be overinflated.
According to this video (ok it's a 6.0), there should be a fist of room under a 2M height restriction but the one on the showroom floor was definitely over that by about 30mm.
It also looks so jacked up at the back that it could pass for a wheelbarrow. The top of rear arch is slightly further off the ground than the top of the front one. The crease line in the body is about 5cm higher at the back than the front. If it was level the van would be within a few mm of the brochure.
