cajunflyer
- Messages
- 10
I'm afraid not knowing which vehicle you have and which roof, manual or Hydraulic, all I can suggest is compare side to side, any difference?My roof isn’t closing.
sitting about 2 inches proud front right corner. I found the black plastic clip snapped and in gulley. But the hook (second picture) now has witness marks.
any ideas? We are supposed to be leaving site this morning.
This is a link to the Parts DiagramApols. 2016 Ocean. Electric roof
My roof just done same yesterday, no idea what caused it.My roof isn’t closing.
Will get some Nik, never happened before , going off through Europe in 3 weeks, don’t want this to start. Especially abroad. Thanks for info. wonder if I have to replace the plastic broken piece.Mine regularry would stat proud about 2" on drivers side only. I sprayed some silicone polish (thetford loo seal spray) onto the upper roof scissor slider as this needs to slide forward to allow the roof to lower. At same time i sprayed all hinge pivots. Worked roof up and down several times then wiped excess spray off all parts. Has since not had a problem, repeated 6monthly at same time as flushing water through roof drains.
great, feel bit better now. will get part when i return. thanks for reassurance.I had one of those broke on mine for ages. Fits on the main lift scissor. Nothing to worry about. The bits were probably caught in the roof somewhere. Throw it away and enjoy the trip. Vw will post you a new clip they don't cost much
