ChrisandPenney52
Hi,
Not sure if this is should be in 'Bodywork' or 'Awning' but can't find a similar post at the moment.
The offside roof rail of my 2008 SE has started to allow water to come between it and the bodywork. This is the rail that holds the screw-in nuts that can slide along the rail and which terminates at the pointy black body trim at the top of the windscreen.
This means that the previously water-tight seal of the space between the awning and the body now leaks, and the step of the sliding door is getting wet in the rain. It's not the rubber strip between the awning and the body that leaks - that is fine, I think!
Can anyone offer advice about possible solutions? I wondered about a tube of sealant along the top edge, but this edge is where the pop up roof meets the body when the roof is down.
I have had my roof paintwork fixed, about 18 months ago, but I'm not sure why I've only just noticed this. Hard to say whether something in the repair and reassembly caused it. The pointy black bit is not as well stuck down as it was either, but maybe just the ravages of time.
I've attached three pictures that show where it's leaking.
[Edit: made the main leak picture big enough to see!]
