Jabberwocky
Forever young (ish!)
Hi @liaoyang , I had one particularly bad leak as described above that was between the rail and the van body. I did not remove the black aluminium rail. I removed the awning and it's two brackets only. This was required in order that I could place the 3M tape across the bonded joint between the rail and the van body. The tape was applied to the whole length of the bonded joint. Circa 2.5m. The tape was merely applied to exclude water from the bonded joint, not as any form of fixing of the rail to the body.@Jabberwocky Ours leaks between the channelled black aluminium rail and the vehicle body and drips onto the step like the op. Was this your problem? If so to clarify, you removed the awning, then the 2 awning brackets then the black aluminium rail and restuck it with 3m tape? Was is difficult to unstick the rail and did you then have to remove what was sticking it before? Cheers
The tape I used was: https://www.vikingtapes.co.uk/produ...rethane-protective-tape-short-rolls-25mm-x-3m . VW use this type of tape in a number of locations on the van already
Hope this helps.
