owen_h
Even the driver’s side rear looks out of plonk
It’s sat way to Low twisted probably
Says it has air suspension (with a leak or broken air line probably?)
How far would i have to drive it and do you have a sea view,Thats some advert:
MODERATE NSR DAMAGE - i dont think so
STARTS AND DRIVES - Im willing to bet my house it doesn't drive
Boilers on the blink but the garage is sound enoughHow far would i have to drive it and do you have a sea view,
also, before i take on this bet, is the house structurally sound
and has the heating been recently serviced
One last thing, have you told the missus![]()
I was thinking 5 metres not 500.Boilers on the blink but the garage is sound enough
Round the block would qualify. In four wheel drive, using all the gears and a reverse park finale utilising the ‘as advertised’ front and rear parking sensors.
I can’t believe the rear window is still intact.
Good friend of mine is UK MD of Copart. They don’t take ownership of the vehicles, they just host the auction website to facilitate the sale otherwise i’d have maybe looked at a deal.Another salvage Ocean up for sale. Hope nobody hurt.
Maybe like @paul_f says above, it wasn't occupied.I just hope that the oppupant/occupants are all ok. As long as they are alright, the van can be replaced. Very sad to see a Cali end up in that state though.
Putting on my deerstalker for a moment, looking at the front offside damage it looks rather like a heavy glancing blow as the bottom of the door is torn backwards. There is also a dent in the A pillar and the awning is missing. Perhaps the other vehicle was a lorry and its mirror caused that dent and ripped off the awning as well before it rolled over. Curios why only the drivers seat airbag went off though.
For an airbag to go off doesn't the ignition have to be on?Maybe like @paul_f says above, it wasn't occupied.
If it wasn't occupied and there were no injuries to anyone, i would
be tempted at 3k and drop it at the bottom of the garden.
Aha... Your Deerstalker is good Boris.For an airbag to go off doesn't the ignition have to be on?
The add says it has been rolled.I would suggest that has been hit on the offside by a lorry on squashed between a concrete wall on near side, such as a motorway bridge
edit: looks like the Cali was going faster than the vehicle that hit it for example lorry crosses infront of Cali, Cali takes avoiding action and is squished between larger vehicle and something solid (concrete)
Cant see that the has been rolled, despite what the add saysThe add says it has been rolled.
I spent a couple of minutes trying to work out what had happened.
Can you come back to me with an answer? You've got all night
tomorrow when i'm having my breakfast would be perfect![]()
You may be right however checkout the striation marks on the rear nearside wheel arch and N/S A pillar. They suggest that it's been moving on its side whilst at right angles to the direction of travel.I would suggest that has been hit on the offside by a lorry on squashed between a concrete wall on near side, such as a motorway bridge
There are dirty footprints on the cab roof lining,Cant see that the has been rolled, despite what the add says
That could just be from when it was last serviced.There are dirty footprints on the cab roof lining,
Having seen this happen when a Lorry squashed a car, the vertical marks on the wheel arch, a pillar etc could be caused by the vehicle being squashed against an immovable object, the forces cause the vehicle to dive at the front and rise at the rear, during the compression (squeeze) the vehicle initially dives at the front, rises at the rear then falls via gravity when the speed is scrubbed off, the resultant damage allows the vehicle to change shape around the immovable object. IMO the damage to the near side is fairly minor in comparison and not conducive with 3 tonne vehicle sliding on its side?You may be right however checkout the striation marks on the rear nearside wheel arch and N/S A pillar. They suggest that it's been moving on its side whilst at right angles to the direction of travel.
Not bad Watson.Having seen this happen when a Lorry squashed a car, the vertical marks on the wheel arch, a pillar etc could be caused by the vehicle being squashed against an immovable object, the forces cause the vehicle to dive at the front and rise at the rear, during the compression (squeeze) the vehicle initially dives at the front, rises at the rear then falls via gravity when the speed is scrubbed off, the resultant damage allows the vehicle to change shape around the immovable object. IMO the damage to the near side is fairly minor in comparison and not conducive with 3 tonne vehicle sliding on its side?
the blown front of tyre would cause the vehicle to try to veer right, caused the load to transfer to the rear of the vehicle
The foot prints on the head lining are greasy foot print, the heel is toward the screen, I wouldn’t have thought anyone driving the Cali or as a passenger, pre accident, would have had heavy greasy boots on like that, otherwise the footwell would look the the black hole of Calcutta !
Recovery drivers will do what they need to do to make a load secure, it’s most likely that the recovery driver has kicked the roof lining in an attempt to close the passenger door, which looks like the door is binding on the roof support.
how do you like that Mr Sherlock ?
Oh I don't know the VW badge on the front looks OK and the 4Motion one on the back.Not bad Watson.
Whatever happened to it there doesn't seem to be that much that isn't now totally wrecked.
Now up for sale on this forum, any takers now it's been fixed??Sorry to see this Cat S 4mo for sale and hope the occupants were ok after a nasty rear end. Not sure there’s much Cali left to salvage for over £15k+vat though.
55K for a 3 year old van that would give you engineer report and insurance headaches year on year. Not for meNow up for sale on this forum, any takers now it's been fixed??
