DoctorBob
how about 19” ........Get some 18s on there.
Happy medium.
Bit more wheel and less rubber, so aesthetically pleasing, but not to much that it comprises the ride.
Happy medium.
My T6 Beach came with 16" alloys & I changed to VW 30mm lowering springs & 18" Sportlines at the same time.
Whilst it looks dramatically better IMO the ride is worse, though not unbearable - I'm not fluent in describing ride, but I think I'd call it "crashy" on anything below a good surface. Previously much smoother, but also "wallowy" especially in & out of roundabouts.
If I ever swap vans I'll stick with stock suspension & 17" alloys next time.
Reduced, But they are available in the right load rating?I think with 19" wheels you are also massively reducing your tyre choice available, far less common.
Be careful with spacers and wider wheels. I have 9J And 45 offset wiithout spacers and the sliding door is just 5mm from the tyre wall!Have 20’s and Goodyear Asymmetric 275 35 R20 with Eibach coilovers. Nice supple ride.
Of course it is !
I've never really understood this lowering, stiffening, bigger wheels thing. VW have probably spent millions on finding the optimum set up for the wide spectrum of possible road conditions and driving styles. Their "one size fits all" set up won't be perfect but i can't see a good enough reason to mess around with it. As Granny Jen says "it's just a van".
However, it's a VW and they've always been modified.
[/QUOTE
You’re entitled to your opinion but there is no need to be offensive.Bling beats brains. True story.
Are you sure about the tyre size as a 255/50/20 will give a 9.5% speedo reading error? 18" has a 45 with same width.I was merely commenting that just the fact you have coilovers fitted doesn't necessarily mean you can't get a jack under, blow out or not. I will need to go and specifically check the minimum required height to get the VW supplied jack under, as I don't know that. I do know that VW supply coilovers and 20" wheels.
Their tyre size of choice is 255/50/R20 FYI.
Got this size from the VW accessories brochure, but yes it does look wrong to me, so sorry for that!Are you sure about the tyre size as a 255/50/20 will give a 9.5% speedo reading error? 18" has a 45 with same width.
Looks more like an Amorak fitting as it matches the original on that.
I've been thinking about getting the VB air suspension. I've got a T6 Ocean (4 Motion), I want more ground clearance as plan to take it to some tricky places. Any idea what the best tyre/wheel combo would be to give max off road clearance but still make it good hacking across motorways in Europe? Thanks!@DoctorBob , sorry cannot help with your specific query, but, if you are interested in trying/testing out VB Air suspension, I am nearabouts you - in Newbury. I don't mind a drive to show you the van.
Eliot, we have had the VB air suspension fitted since new and it has been a very good investment (the best investment).I've been thinking about getting the VB air suspension. I've got a T6 Ocean (4 Motion), I want more ground clearance as plan to take it to some tricky places. Any idea what the best tyre/wheel combo would be to give max off road clearance but still make it good hacking across motorways in Europe? Thanks!
