Ok thanks not something I would use....or know how to use!I would expect media mp3 files
You can insert the navigation SD card in both slots. The radio will pick up the navi data from the SD card, regardless if you put it in left or right.Ours has one on the left of the screen which is for Sat Nav there is also on the right of the screen for the Media.
You put your music on the SD card, put the card in the radio, press media, listen to your music!Ok thanks not something I would use....or know how to use!
never even consider thatYou can insert the navigation SD card in both slots. The radio will pick up the navi data from the SD card, regardless if you put it in left or right.
Yes sounds good however my music is on my Iphone and that means accessing Itunes which firstly is a nightmare to navigate and Apple wont allow you to download music to another source but I guess if you have Android it may work...but then again whats the point of putting music on to a card when its on your phone and you can connect it via app connect? all a bit daft if you ask meYou can insert the navigation SD card in both slots. The radio will pick up the navi data from the SD card, regardless if you put it in left or right.
I don't have a T6 radio, but tried it on my dad's T6. It worked, as well as the newest navigation map update 2020! (already) (and for free!)never even consider that
As long as you have a signal of course. Some people visit places that don’t have good reception.Yes sounds good however my music is on my Iphone and that means accessing Itunes which firstly is a nightmare to navigate and Apple wont allow you to download music to another source but I guess if you have Android it may work...but then again whats the point of putting music on to a card when its on your phone and you can connect it via app connect? all a bit daft if you ask me
