Yes, and drain the Water tap and pipe work As per the Handbook.Hi there,
we have bought a new Cali, and are new to cold countries (we leave in Munich now).
we were wondering if we need to empty the water and waste water tanks due to the risk of freezing.
See here for methods to drain water tap and pipe work.Thanks. Unfortunately I got the handbook in German. Need to order an English version. Anyone knows if there’s an e-version or the handbook?
If you send me an emailadress, i send you a copy via google drive (75 mb)Thanks. Unfortunately I got the handbook in German. Need to order an English version. Anyone knows if there’s an e-version or the handbook?
My email : olaf.mourant@+++++.comIf you send me an emailadress, i send you a copy via google drive (75 mb)
Problem doing that is you risk running the pump too long without water going through the impeller and it may knack the pumpCan I ask a possible silly question...?
If you empty the tanks and run the tap until no further water emits...?
Wouldn’t this system now be empty instead of pulling fuses etc.
Or am I missing something...?
I have done the same for the last 10 years without any problems then I leave the water tank valve half way.Fair comment.
This is what I’ve done last year and this year, being mindful not to run the pump to long...
