D
Dill Tart
Dilltart
A couple of weeks into our recent trip to Norway the sink tap stopped working. Moving the lever to the vertical position would emit a click (micro switch working) but no water, the shower (same pump) was working.
I found a very useful link on the site to show how to clean the contacts in the microswitch, beginners error, I didn’t put the plug in the sink and the minute spring piece of the micro switch disappeared down the plug hole!
We managed by turning the tap on, removing the lever & pressing the contacts together, a fiddle but it worked for two weeks.
I ordered a new micro switch, & just to be sure, a new tap from the club shop. The old micro switch is almost impossible to remove without damaging the tap, I carefully prised the switch out but half the black base came with it! Result … it was binned along with the new switch.
The new tap was a doddle to fit in 20 minutes, it had the correct electrical terminal already fitted and worked.
Just suggesting that this might be an easier option.
