It’s tight but if you take out one of the drawers under the 3 seat bench (there’s a load through hatch for each drawer in the back of the bench) you should be able to slide paired skis on their sides, though the hole provided your skis aren’t incredibly fat. I don’t think any bindings will fit through though. Also, a snowboard sitting on its base will also slide ‘through’ (into, really - not all the way through) . I fitted the tips of 2 boards in a board sleeve under the bench which was just enough to load them in a straight line front to back. Unfortunately it’s tight and the bag snags on the trim which just makes it a bit of a faff... hope that helps.. StuHi everybody, I'm going to buy a Cali Beach at some point this year, but I'm still deciding between the two and the three seat bench.
I was wondering, is it possible to store the skis underneath the bench?
Thx in advance!
That was exactly what I was looking for, thank you!It’s tight but if you take out one of the drawers under the 3 seat bench (there’s a load through hatch for each drawer in the back of the bench) you should be able to slide paired skis on their sides, though the hole provided your skis aren’t incredibly fat. I don’t think any bindings will fit through though. Also, a snowboard sitting on its base will also slide ‘through’ (into, really - not all the way through) . I fitted the tips of 2 boards in a board sleeve under the bench which was just enough to load them in a straight line front to back. Unfortunately it’s tight and the bag snags on the trim which just makes it a bit of a faff... hope that helps.. Stu
Q
Are you aware if the same is possible for a two seated bench?
