FredFlintstone
Hoping to tap into someone's experience here.. Sliding door would jerk when closing to start with (when triggered by the keyfob), now it doesn't close from the keyfob, it will open & close from the cab button (which now flashes).
It will also open from the outside handle & from the inside handle. But refuses to close from either.
Is there any repairing of the seal sensor to be done, or is it a straight replace only fix?
VCDS flags up the following issues:
2 Faults Found:
02356-Data Transfer to Sliding Door
012-Electrical Fault in Circuit - Intermittent
02366-Pinch Protection
011-Open Circuit
Best regards
2 Faults Found:
011-Open Circuit
Best regards
