CaliforniaSteve
Steve B
Hi All
I had the sliding door blind fixed under warranty a couple of years ago (it wouldn't stay down). The bottom fixing has now fallen off as it t was glued on. The lower panel trim is out of alignment with the upper one and therefore the fixing isn't in line with the blind. Has anyone had experience of removing or replacing the lower trim, should the fixing at the bottom the channel be glued on or can anyone direct me to a parts diagram? Thanks
