SLIDING DOOR BUZZER ?
K
KEV356
YORK NORTH YORKSHIRE
Does anybody know where the sliding door buzzer is fitted.
I want to disable it...it is annoying when you want to exit in the nite for a pee and don't want to wake every body up !!!!!! :grin:
Regards
KEV356
I do not believe that it is possible to disable it to be honest.
cheers
Martin... Known as T5WOB, has a solution to this...
You'll probably not like it though... :)
I'm sure he'll be along in a minute
KEV356 said:
i know Martin...I can guess !!!!.....stick a screwdriver in it !!!!
:grin:
That's the one... And yes he did :)
not dun it yet, but on the to do list .mate a vag teck says the best thing to do to it is screw driver thought it ..we did try vag com but no luck . :D
Ok so where exactly would you stick the screwdriver in (excuse Pun) :D
ok maybe i am being a bit thick but where is the black box that makes the noise with my dodgy hearing i cannot tell where the sound is exactly coming from is it behind the rear ventilaition control panel and if so how do i remove that without damaging anything
think its behind the panel under the side window .need to push seat forward .that all stuff out the back of van .
6K
ChrisandPenney52
ChrisandPenney52
FredFlintstone
kurienp
kurienp
drmanhattan
mackem10000000
