Sliding door issue T5 2007
T
Trevor Munro
Aberdeen
T5 SE 174
Hi,
Has anyone has an issue with their door sometimes not opening from the outside i can get it open from the inside also the handle seems a bit loose ?
Thanks for any advise !
I assume you do mean "opening" and not unlocking. I had something similar on my T5. From what I understood there is a lever on the opening mech that needs to be "cocked" in order for the door handle to open the door. This lever can get stuck or become sticky. If it is not in the "cocked" position the door will not open. If stuck you will need to remove the door card to get to the mech and see what the problem is. There is a small spring next to the lever that gets in the way of the lever if the spring moves. If just sticky, I found a good squirt of WD40 works. Alternatively a visit to VW.
danvan
6K
M&Jsblucal
Sp0_0k
Sp0_0k
Sp0_0k
Meoncoast
Jabberwocky
Jabberwocky
Hawthorn37
Vagophile
V
