Sliding Door Operation Not Smooth
X4 VWC
X4 VWC
Essex
T6 Ocean 204 4Motion
I've a new T6 Ocean and the sliding door appears to grind inside the side runner due to resistance at several points along the runner. I've used several T5/T6s vans in the past and never noticed an issue but the door is definitely not as smooth as it should be. Dealer has offered to sort it out but it's a bit of a drive and I'd like to know if there's anything that I can do to fix it myself.
Moderator - please can you move this to T5/T6 chat as it's relevant to both. Thank you :)
There is a long list on sliding door problems (if you do some searching), some even scratch the bodywork ....
Think you should only do one thing here and tell your dealer to sort it out.
Ps: moved the tread;)
superchoward
17K
KGCali
KGCali
burnercan
Volkywagen
Volkywagen
Bobi2sox
CampervanTime
6K
MyrtleMoo
ElectroMech
E
