Sliding door window
Jandy61
North
T6 Cali On Order
Hello
Sliding door opening window, is a must have option? we are going for a Coast do an option.
Also while I’m here, can we get a full chrome pack fitted to a Cosst so it matches an Ocean with a chrome pack option
Hello
To answer your first question - based on our use case, Yes. When in colder climates, and cooking inside, cross-ventilation is required and this helps us to easily open the window for cross ventilation.
In warmer weather - again, you can leave the window open, rather than keeping the full door open.
Having a window also enables you to use devices such as window metal blinds to enable cross ventilation at night.
Hope this helps. Someone will be along to provide info on the chrome pack. :thumb
That’s great info, makes sense now thinking about the ventilation,
one last box to tick
You can source the Chrome parts individually which can be a cost saving. Care needs to taken in getting the Right Hand Sliding door version. UK standard kit for vans would be Left sliding door.
Can be sourced via Ebay.
