dspuk
Dave
Roger you have an email address please?
Let Me Google That
For all those people that find it more convenient to bother you with their question than to google it for themselves.
Thanks WG - top tip.Don’t use a Pressure Washer on the sliding windows, prone to cause leaks.
Thanks ThomasHJ!Ours is parked on our drive under multiple trees so it gets green quickly. The pressure washer perfectly cleans all of it easily. I don't think the roof's material is in danger. However, the paint of the
rest of the van is a different story. Don't set your pressure washer to high. I know I have made 'spots' when I set it to high, where I've chipped the paint.
The industry standard for most solar panels' lifespans is 25 to 30 years. Most reputable manufacturers offer production warranties for 25 years or more, that is for those mounted on domestic roofs, clearly on a camper, they are likely to have a slightly harder life, but nonetheless, 15 years should be a minimum.
Some panels from 1982 are still going strong: "In the Swiss canton of Ticino, one of the longest-serving photovoltaic plants in Europe is in operation. The plant with 288 modules on an area of almost 500 square metres has been generating electricity since 1982. It is still running today."
Just fitted a two panel kit a couple of weeks ago from Roger. Excellent kit, easy to fit and very robust.how long should these panels last? I'm just starting my research into Cali Solar, hence the question![]()
About two years if you buy from Roger/Solar Camper Solutions. Somewhat longer if you buy from somewhere else. That’s my experience anyway!how long should these panels last? I'm just starting my research into Cali Solar, hence the question![]()
3 years so far from Roger; excellent product with no issues.My experience is 4 years to date for my panels from Roger, still going strong.
Do I understand this correctly, i.e. you are not pleased with the panels from Roger ? I ask because you are the only one that I've read until now that is not pleased with the performance of his panels ?About two years if you buy from Roger/Solar Camper Solutions. Somewhat longer if you buy from somewhere else. That’s my experience anyway!
I’m not happy at all because I’ve had two failed panels from him. The first lasted about 18-20 months. This panel and all ancillary electrics were fitted by him. After a lot of chasing, he agreed to replace the panel ‘at cost’ (about £60 if I recall correctly) even though it was within the two-year guarantee period. I expected him to honour the guarantee in full but it wasn’t to be. This second panel has now died, again after about 20 months. The problem is the panels supplied by SCS appear to be unbranded Chinese ones. You may get a good one - or maybe not. You also can’t contact him via phone (my emails went unanswered). I’m an investigative journalist so I got his mobile number easily enough from details I tracked down via Companies House. I’m now about to buy a panel from Renogy and simply wire it into the original charger. I‘m also considering a free standing panel from a reputable manufacture. If I was to start from scratch, I’d go somewhere else or do it myself.Do I understand this correctly, i.e. you are not pleased with the panels from Roger ? I ask because you are the only one that I've read until now that is not pleased with the performance of his panels ?
I‘ve had similar problems with Roger’s panels (two have now failed). Did the Renogy panel fit into the frame supplied with the SCS panel? I’m looking for a panel that can, ideally, be glued on top of the one supplied by Roger and then connected to the curly/telephone style cable fitted by Roger to the charger.But the bin bag I had to put my solar panel I bought from him after only three years was black! I now have the original's rails with a new solar panel (a 175Watt one from Renogy) that’s lasted three years plus….
To be fair, he’s changed the type of panels he sells, so hopefully the current ones last longer, modern panels should have a 20yr lifespan or more.
Very neat ! - I might adopt those cable clip sticky pads - are the strong in terms of adhisive?Hi all,
I have just installed myself a kit of 3 panels from Roger and so far so good. ,
@Roger Donoghue What Amps should I be getting from one of your 4 year old panels? I never seem to get above 3.3a even when aligned as perfectly as possible (I thought it should be around 6a but it is old obviously).
Is that normal or is there something amiss?
(Also due to having your panel and kit installed since I've owned the van I've never hooked up to EHU - and only last week tried it just to see how it works - the Solar has been a brilliant addition).
Yeah - I have Epever Duo MPPT so maybe that's part of the issue.It will very much depend on what the van "needs" aswell as the panel condition, and the time of year. It should still give you good power after 4 years. If your battery is close to full it'll drop down the charging rate regardless of the sun. This time of year you'll see far lower amps than in summer, even on a sunny day, as the sun is much lower in the sky.
In the summer, with the correct demand (1st thing in the morning after a night of fridge running) I'd expect to see over 5.5amps with the roof raised. New, they peak over 6amps - but bear in mind, if you have an Epever charger - it doesn't show the MPPT "uplift" like the Victrons do - you see the panel amps on the Epever Duos, not the battery charging amps - and the difference can be significant.
When I do installs in the summer I see these kind of numbers when I plug in the MPPT, but, they quickly drop as the battery reaches near-full (as they've driven to me the batteries are usually already close to full).
Hi Roger,Very neat ! - I might adopt those cable clip sticky pads - are the strong in terms of adhisive?
you should prepare the surface with Isopropanol alcohol before applying the sticky pad, any hint of grease buggers up the stickiness of the padHi Roger,
Some yes and some no XD
From the same batch, ones stick very well but others don't. Maybe it is me.
Now I believe that we have to stick them and leave them for a while before putting the cable.
Maybe you can find a good brand.
They look very neat though.
Thanks again for the selling the kit. It is great.
Cheers,
Manoel
