Ch1pbutty
Are the panels sturdy at motorway speeds? through Germany 160 and sometimes to 180km/h is what I usually do. These vans move!
Yep
All I'll be using power for will be the fridge and occasionally phone and garmin watch, nothing else so 100w should be fine. Kettle runs off gas. We're campers at heart so no air fryers, coffee machines, laptops or tv's. We only listen to music when travelling. Our Cali will be used as glorified b&b as once up and washed it'll be hike boots & rucksack on and out for day; snack lunch and either pub meal in evening or meal cooked on gas rings inside or portable gas stove outside. We'll then perhaps sup wine till late with wife reading or simply admiring the views whete ever we are while I may have head in map working out next adventureHi James,
I have a 230amp Fogstar underseat Lithium. But even with solar and a Victron dc to dc charger (instead of the original split charge relay) it can take a while to top up, especially if just solar. So again it depends on what your use is.
On the brightest most efficient day at best solar(200w) will only give 10-15aph.Engine charge included then maybe up to 30aph at best.
My 800w kettle draws around 70amps through an inverter, the air fryer maybe 85-90amps.
I don’t have a portable power unit but I am guessing (not sure) it charges via a 12v socket which would not give much more than 10amps I would think. A 100w solar on a good day maybe 7amps per hour. It would take a fair while to top up if you run any mains kit.
I do like the idea of the friendly pub for a plug in, especially if your portable unit has its own wheels.
All I'll be using power for will be the fridge and occasionally phone and garmin watch, nothing else so 100w should be fine. Kettle runs off gas. We're campers at heart so no air fryers, coffee machines, laptops or tv's. We only listen to music when travelling. Our Cali will be used as glorified b&b as once up and washed it'll be hike boots & rucksack on and out for day; snack lunch and either pub meal in evening or meal cooked on gas rings inside or portable gas stove outside. We'll then perhaps sup wine till late with wife reading or simply admiring the views whete ever we are while I may have head in map working out next adventure![]()
In the shade they will give you about 0w. They need a clear view of the sky and the best is the sun. Further, the hotter it is the more power the fridge requires and the efficiency of the panels drops somewhat but the shade does not make up for that.I didn't think you needed direct sunlight but more daylight for them to work. They don't like getting too hot. I know that from my home one's which seem to generate the most first thing in mornings before it gets to hto at moment
interesting...In the shade they will give you about 0w. They need a clear view of the sky and the best is the sun. Further, the hotter it is the more power the fridge requires and the efficiency of the panels drops somewhat but the shade does not make up for that.
I’d be interested in understanding how you did this, I’ve also got a single 100w panel and the victron, already have a delta 2 which charges off the load side, have considered a portable panel to give me some optionsI've added extra cabling so the portable panel can be wired in parallel with the roof one and potentially give me 320w, but in reality it's usually just over 200w and I think the controller won't use much more than that anyway.
This was one of the reasons we upgraded to two panels from one; a single panel is adequate if you have a nice open pitch, but if you're forced to pitch under partial shade and only get direct sun for a few hours at most, then it means we can utilise the bit of light we get that bit more. If you're completely under trees, like you say, you get diddly squat no matter how many panels you've got. A few campsites we stayed on in France were like that, basically parked in a dense forest, lovely and cool but you'll need an alternative power source to solar if you're there for any length of time (unless you have a solar panel mounted on a 20m telescopic pole you raise above the tree canopy).In the shade they will give you about 0w. They need a clear view of the sky and the best is the sun. Further, the hotter it is the more power the fridge requires and the efficiency of the panels drops somewhat but the shade does not make up for that.
Hmmm... not always unless you really have deep cover. I've noticed my panels on my home still generate reasonably well on cloudy overcast days and right up till sunset when sun it behind trees going down. It does depend on how good the panel and controller are so I can't give any opinion on the ones on a Cali, only my home. Yes I understand fridge works harder when sun out in full in summer but you're also generating more power. For my use I won't be stopping under trees anyway as bad idea in UK with weak branches and in any case hwn we travel it's never that hot.In the shade they will give you about 0w. They need a clear view of the sky and the best is the sun. Further, the hotter it is the more power the fridge requires and the efficiency of the panels drops somewhat but the shade does not make up for that.
I thought I could remember reading somewhere in my early days of Cali ownership, that when the leisure batteries were "topped up" by solar, the leisure batteries then trickle charged the vehicle battery.Get one of these and plug one end into leisure battery 12v plug, the other into 12v engine battery plug. It will trickle charge engine battery from leisure.
Streetwize Charge and Go-Car to Car Starter | Euro Car Parts
Streetwize Charge and Go-Car to Car Starter at the lowest UK prices from Euro Car Parts UK’s No.1 for Car Accessories, Car Styling & Car Care. Buy today Online, In store or by Phone + Branches Nationwide – Next Day UK Free Delivery.www.eurocarparts.com
I think Rogers website says similar as well from memory, either that or that the is a trickle charge from the solar to the starter battery, but only about 1 amp (?) i'll have to go back to his website to make sureI thought I could remember reading somewhere in my early days of Cali ownership, that when the leisure batteries were "topped up" by solar, the leisure batteries then trickle charged the vehicle battery.
Did I dream this and is this then total b*llocks?
In my defense, I read so much stuff in my initial info-gathering stage of ownership, that I could have got confused![]()
It does on T5.1/6 but not by design. VW says No , but I've proved it to my satisfaction. Regularly park at Heathrow for 5 weeks or so and always starts.I thought I could remember reading somewhere in my early days of Cali ownership, that when the leisure batteries were "topped up" by solar, the leisure batteries then trickle charged the vehicle battery.
Speedy! You are getting close to the maximum speed rating of some factory fitted tyres there. 3000kg at 180km/h is a lot of kinetic energy. Hope you have the larger brakes fitted.Are the panels sturdy at motorway speeds? through Germany 160 and sometimes to 180km/h is what I usually do. These vans move!
Google suggests there are loads of them, from no-name through to Husqvarna.'wonder how long before someone invents solar power lawn mower'.........(you can see we have interesting chats lol!!! Is there one yet..................................
Apologies for being an electrical numpty, but I don't quite get the principle of using 2 voltage meters, so I'm unsure as to how to go about using both to test if the vehicle battery is receiving a trickle chargeIt depends on the individual van, as for some unknown reason VW did not wire them all the same - hence no fuse diagram in the manual!. Some vans do, some don’t. Easiest way to check is to get 2 plug in voltage meters (and see if the engine shows a charge voltage when not running / on EHU, when leisure battery is fully charged).
I now have a T5.1 Club Joker, engine charges when leisure has surplus.
Apologies for being an electrical numpty, but I don't quite get the principle of using 2 voltage meters, so I'm unsure as to how to go about using both to test if the vehicle battery is receiving a trickle charge![]()
I guess one would go on the vehicle battery, but does the other one of the leisure batteries?
If you would be able to give some detailed how-to, it would be much appreciated. Thanks
Except on our MY23 I discovered (after much initial confusion) every 12v socket on the vehicle is leisure; the one by the gearstick, the one on the dash-top, the one next to the sliding bench and the one in the boot. On the drive, engine off, they were all reading 13.7v (solar panel was on float); a voltmeter on the van battery confirmed 12.7v (and I checked and confirmed the plug-in voltmeter was accurate too), so they're definitely all connected to the leisure battery. Bit frustrating actually as I wanted to measure the vehicle battery easily!Something like this plugged into cigarette socket will allow you to see voltage. You can do it with one, but with two you can easily monitor both at the same time.
Rear sockets are leisure, one dash socket will be engine (2nd dash socket can be engine or leisure according to year!)
Now, I am confused as to what I need to do,Something like this plugged into cigarette socket will allow you to see voltage. You can do it with one, but with two you can easily monitor both at the same time.
I'm even more confused nowExcept on our MY23 I discovered (after much initial confusion) every 12v socket on the vehicle is leisure; the one by the gearstick, the one on the dash-top, the one next to the sliding bench and the one in the boot. On the drive, engine off, they were all reading 13.7v (solar panel was on float); a voltmeter on the van battery confirmed 12.7v (and I checked and confirmed the plug-in voltmeter was accurate too), so they're definitely all connected to the leisure battery. Bit frustrating actually as I wanted to measure the vehicle battery easily!
Not in my case, see above. Tested with a voltmeter when the leisure was on float and the vehicle battery was sitting at rest at 12.7v. I was sufficiently confused to double check with a proper voltmeter (as opposed to a plug-in one) and it agreed. All four of the 12v sockets on my van are leisure-powered.All of the cigarette 12v sockets behind the front seats run off the leisure battery, the ones in front run off the starter battery.
It was quite simple, basically added some extra XT60 connectors - the same as the solar panel input on the River 2.I’d be interested in understanding how you did this, I’ve also got a single 100w panel and the victron, already have a delta 2 which charges off the load side, have considered a portable panel to give me some options![]()
Same. The mid to last 6.1 all the same. Not sure when VW made the switch. Caused confusion at first when I was monitoring starter via the front 12V and it was reading the same as leisure.Not in my case, see above. Tested with a voltmeter when the leisure was on float and the vehicle battery was sitting at rest at 12.7v. I was sufficiently confused to double check with a proper voltmeter (as opposed to a plug-in one) and it agreed. All four of the 12v sockets on my van are leisure-powered.
