SPARE WHEEL AND CAGE
fordyski100
fordyski100
T6 Ocean 204 4Motion
Can anyone help me with information on spare wheel and cage.
I would like to fit spare wheel to My Berghaus California , but am advised the Dakar wheels are too big to fit cage and i will need to use a steel wheel as a spare.
No problem doing that , but can anyone confirm size of wheel and tyre that will need to be fitted as i am guessing overall profile will need to be the same?
:thanks
There has been quite some discussion already on this and hopefully if you search you'll find the thread with the part numbers.
Ideally you want a 17" wheel, preferable new and quite likely to have been remove from a van undergoing Sportline transformation.
T
Cheers Stu , ill start searching .
If anyone has the list of parts to hand that would be great but I'm sure ill find it .
Thanks again
The parts I have, and the ones I think you need, are as follows -
Spacer Sleeve - 701 801 913 - x2 - £3.60
Bracket - 7H0 801 903B - X1 - £34.00
Pin - 7H0 801 949 - x1 - £1.27
Bush - 7H0 801 917C - x1 - £5.23
Hex Bolt - 701 801 651A - x1 - £8.19
Screw - WHT 003 473 - x1 - £4.71
All prices each and plus VAT.
Thanks Kev Much Appreciated
Any idea on wheel and tyre size (17inch wheel as per Stu but tyre size ?) Only I'm concerned its different to the dakar wheel and tyre or does this not matter?
Not sure where you are located but AB Crush one of the body shops doing roof repairs also happens to be the birthplace of Sportline vans so they have wheels for sale.
I am in Kent so ill give Crush's a ring
Thanks again
You couldn't hope for better then!!
Ask for Julie, mention the forum or me & she'll point you in the right direction.
It's the birthplace of your Berg too. :thumb
