N
NorwayWesty95
Hi guys,
newly registered lurker here, and of course I need your help...
The problem is that my 1995 California Coach no longer charges the battery from the engine.
I changed to an upgraded battery last year, it holds a charge fine and it charges perfectly from the outside socket.
After doing my research on here I was able to locate the relay below the fridge, and lo and behold it was damaged (somehow one pin has broken off).
Any help incredibly appreciated, I don't really know my way around automotive electronics.
The relay I have is a BOSCH 0 332 002 150.
I've seen some of you guys rocking a ...168 instead of the 150, it's the same but with an additional resistor.
I suppose that should work for me as well? Well, unfortunately I managed to order a ..156 model instead, which has a diode instead of the resistor.
Here's the diagram for it. Does anyone know if this will work?Any help incredibly appreciated, I don't really know my way around automotive electronics.
