fozzybear
fozzybear63
- Messages
- 174
- Vehicle
- T5 SE 180
Sounds interesting! So, if you are someone who does regular under bonnet checks the more frequent you end up having an oil change. Think @GrannyJen has the answer, leave well alone!Making use of that space under the bonnet seems like a great idea, but I seem to recall that the number of times the bonnet is opened affects the service interval. If you were to regularly access items stored under the bonnet does anyone know what impact it would have on the service schedule?
Interesting... as you say could trigger an extension to service interval. All a bit OTT!Found it! What do you think??View attachment 41009
When serving my army duty here in Belgium and Gemany we needed to check the oil before taking off with the old MAN trucks....now i know why we needed to change oil every 5000km back then.....we opend the bonnet each day....
If the bonnet is left open for sufficiently long, maybe the vehicle computer assumes a fault and sends you in for a service.Found it! What do you think??
Perhaps the bonnet sensor works on time left open when the ignition is on rather than a bonnet opening count. If, for example, you drive for a period of time with the bonnet sensor showing open, the computer assumes a fault and directs the driver for a service. Closing the bonnet or fixing the bonnet sensor would clear the service indicator.Well I check under the bonnet on a regular basis and have the vehicle serviced annually with about 20,000 miles between services. Last service, after some 19,5000 miles the MFD showed 6,000 + miles to next Oil Service.
