Maybe you are all trying to make life in a Cali too complicated. I figured the bonnet sensor is just to let the driver know the bonnet was open! See photo. Or maybe I am just a simple soul or it is indeed April. Must check my calendar!
Tom, your point is a valid one but I wonder if the whole chart is complete anyway. I would have thought that an average ambient temp might have a bearing on service intervals but this is not mentioned. Also the chart is described as a "....a simplified form" so personally I wouldn't bear too much reliance on it.I wondered the same too but discounted that as all doors have the same sensor but are not on the diagram.
Ah yes, obvious really. This also ties up with what I was told ie if you have an oil warning up then it will go away once the bonnet opens but only for 100km if the oil level is still unchanged.
A bit crude in my opinion.
At least now I know an easy way to make that pesky yellow watering can light go off.
Don’t say that, someone will do just that.Well it's cheaper to open and close the bonnet every 100km than buying more oil.
Sent from my iPhone using Tapatalk Pro
So I check/refill the screen wash battle and the oil check light resets itself? Surely not. That seems bonkers to me. (But then so do a lot of other things! )I think opening and closing the bonnet (switch) assumes you have checked/filled the oil level and resets the check oil light.
........and 100 km later the oil check light is there again.....So I check/refill the screen wash battle and the oil check light resets itself? Surely not. That seems bonkers to me. (But then so do a lot of other things! )
OK. I can live with that.........and 100 km later the oil check light is there again.....
Having owned numerous 1960s and 70s British-built cars, I'm quite used to various warning lights coming on every 100km. (But usually the tinkle of main bearings disintegrating came before that.)
Perfectly safe in my opinion...I have started storing engine oil and a small air compressor and washer fluid next to my battery.
Does anyone consider this unsafe, ie the oil aspect?
Thank you.
You haven't seen my Garage. The kids, Kids they're all over 30, always have a look in the garage when visiting, so some things stay under Lock and Key so they don't mysteriously disappear or get borrowed without asking. Only old, odd tools live in the Garage and Oil Dregs etc: Been caught out too often.Why carry engine oil...?
Surely you check oil regularly? Therefore you don’t need to carry it around.
If the van losses a lot of oil, all of a sudden. You have bigger worries than topping up the oil...????
I always carry a litre around. Mine has got a cover over theDoes anyone consider this unsafe, ie the oil aspect?
