Suspension Upgrade
TimSta'sBeach
TimSta'sBeach
Wheelers Hill, Victoria, Australia
T6.1 Beach camper 150
Hi All,
Looking to improve the off-road performance of our T6.1 4Motion Cali Beach.
The factory suspension is to Soft & it sits a bit low, particularly at the rear (VanEssa kitchen fitted)
Any recommendations?
It is only 3 months old & we don’t want to void the warranty.
Hi All,
From the simplest/cost effective, to the most expensive
Check the markings on the existing spring (colour lines) and see if you want to go to a higher rated spring.
See if you have the thicker ARBs. This does not address the sag issue, but definitely makes the ride much better.
Coilovers or adjustable dampers are the next option. Koni come recommended.
The next step will be a full Seikel kit or the VB air suspension (our Cali has VB air and can highly rate it).
It is a minefield. Start with a budget and that will help a lot!
