Jaco Kruger T4
Hi everyone, I've got a strange issue with my leisure battery, where the voltage on the leads oscillates between 8 and 14V when connected to mains.
Output from the charger is a steady 14V. So something in the middle must be interfering.
I have a Danfoss compressor unit, and looking at the wiring diagrams, I see there's a 20Amp switch (#13 in the diagram).
I presume it's the black unit between my fingers, that when plugged into the socket in the background closes the switch and causes the problem.
Disconnecting this switch solves the problem, but I don't understand why. Could it be that the output current is less than 20Amps, and it causes the oscillation?
Many thanks for any help
Jaco
Jaco
