I
Ianantking
Is my 2015 California SE TDI BMT a T5 or T6?
Do you have AdBlue? If NO then you have a T5.1. If YES then you have a T6.Is my 2015 California SE TDI BMT a T5 or T6?
Also if its a 180 its a T5.1SE as that power output was upped to 204/199 for the T6 OceanIf its an SE its a T5.1 if its an Ocean its T6
Not necessarily @WelshGas I have a 2016 T6 manufactured 14/04/2016 with a CAAC engine and does not have AdBlue but is acceptable in LEZ areas!. I don't think the T6 had AdBlue until the 2017 model nominally 1st August 2016.Do you have AdBlue? If NO then you have a T5.1. If YES then you have a T6.
And to keep it simple: some external features. Look carefully: the T6 is on the right (the straight bottom of the window in the tailgate is especially noticeable and I think the difference is also clear at the front).
T6 came out in 2015, but obviously not from the 1st of Jan. So it could be either a T5.1 or a T6.
If it's a T6, you'll have slightly different features. For example, the dash, bonnet, lights (front and rear), as well as interior fabric and wood effect. A brief google should be able to clarify
Again thanks for that. The consensus is that I have a T5.1.I didnt think it got any simpler, no need to look at anything. - he's said its an SE in the first post, if its an SE its a T5.1
On his profile he shows its a 180 - if its a 180 it can only be a T5.1
I definitely don’t have Adblue but I definitely thought it was an Ocean. Am I the only one to be confused by the nomenclature? From the photos provided by calibusje I am pretty sure I have a T5.1. Thanks for your helpNot necessarily @WelshGas I have a 2016 T6 manufactured 14/04/2016 with a CAAC engine and does not have AdBlue but is acceptable in LEZ areas!. I don't think the T6 had AdBlue until the 2017 model nominally 1st August 2016.
For the OP, if the rear lid has glass with a flat bottom edge it's a T6, if it turns up each end it's T5 (note wing door models didn't have this change).
Also of note is that the front wing flasher repeaters are along the swage line at the back of the wing on a T6 whilst T5 ones are almost oval and lower on the wing.
Just you wait till you start trying to understand the power levels between them all And if that's not enough, then look at the road tax bandingAgain thanks for that. The consensus is that I have a T5.1.
Also correct but I'm afraid it's not that simple: a short 10 second search shows that the OP posted in 2017 that he bought a 2015 OCEAN.I didnt think it got any simpler, no need to look at anything. - he's said its an SE in the first post, if its an SE its a T5.1
Early T6's didn't have Adblue. I've been corrected a few times on that point.Do you have AdBlue? If NO then you have a T5.1. If YES then you have a T6.
VW TRANSPORTER T5
The Transporter T5 was initially manufactured between 2003 and 2010 and is easily the most recognisable and popular Transporter on the roads today. It was given an upgraded look from it's T4 predecessor and features a more modern shape and 4-piece front grill.
This model is often confused with the facelifted T5.1 which came in 2010 and features a reinvented front end.
VW TRANSPORTER T5.1 (FACELIFT)
The Transporter T5.1 is the newer, 'facelift' version of the well-known T5. It was introduced in 2010 and has a much sleeker and differently shaped front end.
The main difference, and way to tell, are the front lights and bonnet shape. As well as looking at the mirror covers. This is the newer, fresher T5; if you have an '01 to '14 plate then it is most likely the T5.1.
VW TRANSPORTER T6
The Transporter T6 is the latest release in the long line of Transporters from VW. It was released in 2014 and replaced the facelifted T5.1.
Many of the updates can be seen under the bonnet and in it's safety aspects, but there is also a clear costmetic update through the headlights and grill.
I've seen people rolling around town with V12 badges on their cars and everyone knows it's packing a V4. Stickers are not definitive.The 10 second search wasn't working earlier!
@Ianantking - you need to be careful re low emission zones, generally T5.1 don't meet the standards but T6 do.
Can I ask, do you have "OCEAN" plastered on the side of the van under the rear side windows? ( thats a less than subtle clue as to what it is) I am surprised no-one has mentioned that as its easier to spot than some of the other clues!
Worked fine at 1:28 pm I mean: I clicked on the name and the OP had only posted 9 posts, quickly read the first one and there it is: he bought a 2015 OCEAN (just to explain how I knew this as far as I can call this a search).)The 10 second search wasn't working earlier!
If there's no stickers when bought at 2 years old it's 99% chance it isn't an Ocean. I mean we could get really technical and suggest looking at the V5 to see what that says, but that would be too easy.I've seen people rolling around town with V12 badges on their cars and everyone knows it's packing a V4. Stickers are not definitive.
