Tomato
My 2021 Coast doesn’t have sport mode, now drives like my 2020 Beach didDrove my 2021 6.1 back from Bognor after gearbox remap, much much better, pulls out of junctions like a spring, doesnt change up to 7th early, highly recommended
Never used before and not since.Do you now use the sport mode?
Great to read, my 204 is going for a Revo remap and TVS at Bognor Motors on Wednesday.Hi Shawn,
I had the drivability update done just last Monday. Paul was the techie that carried out the work. I asked about the 6.1 dsg at the time. Apparently the gearbox s/w is better than that of the T6 but is still lacking. A software upgrade to the 6.1 will still improve further and make a more pleasurable drive.
I would definitely get in touch if I was you, if only for a chat. All the staff are great and so enthusiastic about the work they do.
Since having my Cali done it is a complete transformation from stock. No more vibrations or straining in top gear on tick over, smooth move off with no delay which should take the nightmare out of using the levelling ramps. The kick down on an overtake is amazing, instead of reving the nuts off it before the gear changes up, the gear changes at correct point in the torque band,…… I could go on and on. It is an amazing upgrade.
I Can’t recommend Bognor enough. If further work required at any time, Bognor will be my first port of call.
As said previously, for the cost of labour they will reinstate your original software should you have the need to have dsg work done.
I have to thank members on this forum again for all the information and their experiences prior to me going for this upgrade.
Love to hear if Bognor have had DSG remapping success with a 6.1Great to read, my 204 is going for a Revo remap and TVS at Bognor Motors on Wednesday.
I have used them for over 8 years for servicing, have bought 4 new vans from them over the years and a Revo remap on a Golf GTD.
That vans going to shift in more ways than one!Great to read, my 204 is going for a Revo remap and TVS at Bognor Motors on Wednesday.
I assume that if you carry out this reset the DSG has to then “relearn” to accommodate clutch wear etc?You can reset the DSG clutch bite point / reset the learning function by:
turn ignition on (do not start the van)
press the accelerator full down & hold for 20 seconds
the gearbox may make a noise
you feel a click through the accelerator pedal.
Start the van and drive normally.
Hi Arun,I assume that if you carry out this reset the DSG has to then “relearn” to accommodate clutch wear etc?
Had mine done there, no problems, good service, didn’t have to wait for an appointment. They’ve moved recently. New place takes a bit of finding.CLP Automotive of Sheffield are known for TVS 'stuff'.
So, 9 days in and 1k miles later.Please update on the changes.
Good or bad
