P
Paul Roe
Does the T6 ocean starter battery charge when it is on hookup ?
mine seems to go flat after just over 2 weeks if i dont drive it
which means that when i work away for a couple of weeks i come back to a flat battery
seems worse with the cold weather
Check to see if the Engine Battery is made by MOLL. If it is then next time it goes flat, don’t charge it, phone VW Assistance.mine seems to go flat after just over 2 weeks if i dont drive it
The first time it went flat i thought it was the dash cam but since then i have always unplugged it so was surprised that it went flat again and again as nothing is switched on except the intruder alarmit shouldn't go flat in only 2 weeks is anything draining the battery?
As the service is run by the AA they will send out a routine AA patrol if one of the specific VW Assistance patrol is not available. Insist on the VW Assistance patrol in which case they will give you an appointment time when they will attend.
The reason to do it this way is that VW Assistance can test and change the battery within 48 hrs, or sooner, whereas the AA will just get you started and tell you to make an appointment with your Dealership.
My 4 yr old T5.1 has just been parked up at Heathrow for 4.5 weeks and started 1st time at -2c, with alarm on, so if yours doesn't last that long there is a problem.The first time it went flat i thought it was the dash cam but since then i have always unplugged it so was surprised that it went flat again and again as nothing is switched on except the intruder alarm
Hi All.
Hope VW Guru will reply please.
Does this apply to the leisure batteries also, as our reads 60% to 80% on the control panel when we do not use are California for about 4 days or so.
I attached the mains hook up yesterday to make sure it was reading 100%.
So will check later this week.
Our California was registered on the 25 September,but we took delivery on the
30 November.
Will check what batteries are fitted this week.
Than you in advance.
Alan
Hi @Paul Roe can I ask after it went flat the first time how was the battery recharged ?
It was jump started then left to run for a bit and taken for a Very long drive
My leisure battery is showing 13 volts, but the control panel just shows a flashing symbol for battery status.
The starter battery is reading 8V, sliding door wont even close
Waiting for VW assist at the moment
I must have a fault then.As much as what I’m about to say will annoy a lot of people I’m going to say it because there is a common misconception on this forum that the charger when hooked up charges all three battery’s it does not it only charges the leisure battery’s. The charger never has charged anything but the leisure battery’s. With the engine running the alternator charges all three battery’s engine off the engine battery is disconnected via the split charge relay from the leisure battery’s.
In @Paul Roe case for some reason the battery initially discharged that I agree needs investigating how ever the battery is now discharging rapidly because after the initial discharge the battery was never brought back up to capacity by a long term trickle charge and thus it will not ever regain full operation, modern battery’s cannot be brought back to life by driving the vehicle using the alternator the current is to high to restore a battery. I have no doubt after a full trickle charge the battery will retain its charge. Going forward however it’s life span will now be reduced as the internal plates would have suffered damage.
When placed on Mains Hookup the Control Panel voltage rises to about 14v and the Engine Battery shows 12.7 v. After 12 hrs the Engine Battery voltage rises to the same as the Control Panel/Leisure Battery Voltage.
On Hookup I use the Vehicle ICE system extensively and have never had a problem starting.
Maybe leakage through the Split Charge Relay. Whatever the cause I’m not complaining.
