Most likely a fuse.
These are the ones under the passenger seat.
Mike
Thanks Mike - unfortunately my fuse panel looks nothing like the picture you kindly supplied - nor does it look anything like what is in the manual !!
Thanks for your input though Tim
Thanks very much I hadn’t thought to try the shower that should help narrow it down - thanks again TimTry a search and lots of tips. As said first suspect is the fuse as shown. Tap microswitch under the tap and behind the drawer. Try shorting out the switch or wires to see if the pump runs. Do you have shower connection. Does the pump run from there. If not try banging the tank or filling and emptying again. Other than that you will have to access the pump under the lid in the wardrobe. You will find it tight and may need to make a tool to undo it. Sometimes the pump is just stuck.
