D
DanS
Hi Everyone,
Since realising a long held dream and buying our California (2009 SE auto) last year I have found this forum incredibly useful but I'm now appealing to collective brain as I've definitely exhausted my knowledge/ability and I'm struggling to find a cure.
Not long after getting the van symptoms of the dreaded earth shunt problem starting appearing; control panel flicker, auxiliary heater not working. California Club to the rescue! I downloaded the VIP guide, bought the kit from Listers Coventry and set to work. I can't pretend it went without incident but after much swearing I thought I'd sorted it. Not so; the problems worsened to the point that the 'voltage plausibility fault' message is ever present and no other menus, including the hidden diagnostics, can be accessed. I've now replaced the two leisure batteries (from Alpha Batteries) with fully charged new ones and still no better! To add to the list the electric sliding door's stopped working too.
I'm out of ideas, though it's definitely not beyond the realms of possibility that I've stuffed the earth shunt repair up (not sure how though?). Any help would be gratefully received or equally suggestions on recommended garages in the south Cheshire area. My searches in this respect are also drawing a blank.
Thank you,
Dan
Thank you,
Dan
