On an unmodified California fitted with factory awning then the highest point is the centre of the roof.My only comment would be to remove the awning. It's a fairly straightforward task and probably the highest bit?
I was expecting this, but my vehicle is totally stock and the awning appears to be the highest point, although I may find the satnav/aerial housing may also be quite high.On an unmodified California fitted with factory awning then the highest point is the centre of the roof.
absolutely, but my original question was about the pro's and con's of storing a california indoors, however the photos have clearly taken the conversation in a different direction.Could you reduce the tyre pressure thus lowering the height of the van
Experts suggest the following:-I was expecting this, but my vehicle is totally stock and the awning appears to be the highest point, although I may find the satnav/aerial housing may also be quite high.
