![Chico](/data/avatars/m/23/23526.jpg?1594319482)
Chico
ENGINE WARNING / TURBO ??
Hi , my 2007 Cali 2.5 has the engine workshop light coming on . Its intermittent. tends to happen first thing when you start a journey. If you turn off the ignition and back on again it goes off and then can generally be fine all day . Just drove Pembrokeshire to Cornwall , 6 hours with no problems , no light . Drove to Edinburgh recently , no light . its totally random ? Ive had the van on a diagnostics and it said the turbo was faulty. The mechanic says the turbo is blocked or something along those lines , and instead of cleaning it out , just replace it , as cleaning it out may just result in the problem re-occurring ?? Any feedback on this issue ?
Also if i do need a new Turbo , where do i get one, the correct one , or any other suggestions ?? Oh finally the van doesn't go into Limp Mode !!
