Tv Aerial Access
California_Clarky
California_Clarky
Southampton
T6.1 Ocean 204
I think this has be discussed but I haven't seen an update for quite a while
I am looking for a way to run a tv aerial cable into the cali - I didn't want to go down the window option but wondered if there was sufficient space to run it through the book and gently shutting the door down on it would this damage the cali or the cable.
The other thought was to come up into/down through the gas bottle storage area - as I dont dont use the gas in the van - I assume there is access straight to the outside
TIA
Run it the same way you do a Solar Panel cable - through a small hole in the rear door cable grommet. Then run it through into the cupboard and from there where you like.
There is a question as to why you would want a TV aerial in a Cali, but I'll not ask it ;)
So that you can watch TV
I was thinking of something that was easy to get in and also to remove thats why I wondered about the gas bottle storage area as I believe that has vented access to the outside.
Reason for wanting to watch tv in the cali on those days when it raining very had and your grandchild is getting board we just chill - its a plan B
We have a WiFi dongle which helps on rainy days with the kids. We also have a projector and Amazon Firestick for family movies, TV, etc. It means no aerial is needed.
Just use phone wifi tethering :thumb
generally could also do this to the tv that is wifi enabled but there have been some places I stayed where the site wifi only works need the admin building and the phone signal is none existant
cpjb@btinternet.com
6K
Hotel California
H
N
Raggedroy
Raggedroy
7K
glen
N
nottsknight
N
