I think it will alarm based on the difference between highest and lowest rotational speed so this will relate to highest and lowest pressures inversely.Thanks for your response
It was the other side of the vehicle on the way up which I put down to the side facing the sun at the time. But I only thought this after it changed sides on the way back yesterday. My route through mid-Wales is a diagonal straight line most of the way. These tyres haven't been used in hot weather before, we got the van at the end of September and the winter tyres went on at the end of November. They are Continental 215/60R17C Load range D
Does it operate when it reads above and below the set pressures? I suppose if is measuring rotational speed then it must do as the rotational speed must change in both cases. But I can't understand why a relatively low external air temperature, 20C, would set it off when you were at 35C+ last year.
The article suggests that the temperature rises but quite a lot over a journey on hot roads with high air temperature.
You might get false positives in some circumstances but rarely false negatives.
What size tyres/wheels have you got.
I have 17" running 235/55 with 44psi all round. A 4Motion.
