Is it a factory fitted heater? I've never heard of anyone fitting this controller, but in theory you could fit anothe rcontroller to the eberspacher directly.
If its an aftermarket like a webasto etc should be relatively easy.
It would have to be 3rd Party and the problem you might have is that the Eberspacher Heater provided to VW is programmed to work with the VW Controller you have so it would have to be re-programmed/re-wired to work with the 3rd Party Controller. Not impossible . Might be worthwhile contact Eberspacher direct and ask.Yes. It's the factory fitted one - standard.
Arrrr forget that then. To much hard work.It would have to be 3rd Party and the problem you might have is that the Eberspacher Heater provided to VW is programmed to work with the VW Controller you have so it would have to be re-programmed/re-wired to work with the 3rd Party Controller. Not impossible . Might be worthwhile contact Eberspacher direct and ask.
No point asking VW they wouldn’t have a clue.
If the heater does have to be altered then the fitted VW Controller would be redundant.
