Urgent advice needed
CarolS
Cornwall
Due to catch ferry to Spain tomorrow and have just driven off with electric hook up attached. Not sure what has broken but the display panel does not show hook up attached. Any. suggestions as to a fix at such short notice. Many thanks.
Quite often it's the cable plug end that suffers more than the van end. You might just have damaged that. Have you another cable to try?
Open up plug,
open flap and you should see 2 screws, undo both and you should be able to slide inner part out with cable.
heck if any of the wires has been pulled out. If lucky there will be at least one out.
wire clamping screws visible from the side for removal of broken wire and securing stripped back wire.
OH! make sure unplugged from mains end first.
Hope nothing major.
Each more fish good for the memory (or so I am told)
