Just to confirm the above, I ordered a replacement sender in Feb (I'm now on my third one!), and the very helpful people at VW said:
I can confirm that the part number has been changed again. The original part number was 7H7 068 257. This was replaced with 7E7 068 257 in 2013. The new correct part number is 7E7 068 257B.
The central pipe is stainless steel. The previous plastic pipe cracked I suspect due to water ingress and freezing. I paid about £90 incl. VAT. Installation is easy, if you have a pair of slip joint pliers; remember to reset the control panel afterwards.
From what I remember, the design was changed as a result of feedback, direct to the component manufacturer, from one of the German Cali forums.
