L
leeb
Ok...so a new problem identified which I will put out here. If you fill the GC680 water tank beyond the 100% indicated on the display panel, the tank will bulge significantly causing the grey retaining panel to move outwards and thereby ripping the aluminium retaining strip from the kicker board. So...make sure someone is watching the meter whilst you fill, and do not fill beyond 100%.
Take care when opening and closing the slideing door to check it yourself (if single handed) as the filler cap flap will be sheared off by the door (done this allready). I get the feeling we early purchasers are the testing board and these gliches will all be cleared up in later models. Incidentally there is no warning of either of these problems in the useless california hand book provided by VW.
