andrew bazeley
- Messages
- 342
I've searched the forums and found general discussions about the rather sad position on locating fuses. My problem is quite specific: I recently had a rather pricey Kenwood radio/satnav installed, and it frequently comes up with "start up error". I've learneed that this can be fixed by removing the unit, then unplugging the wiring loom at the back and pushing it in again ( a bit like turning a PC off and on again). I have a hunch, though, that removing and replacing a fuse might have the same effect, with a lot less trouble. Any views? And if so - which fuse is it? None of the manuals (Kenwood or VW) helps at all.
