itscalledbob
Home is where you park it
Oh, starting to look like I’ve spec’d and paid for an option that’s not been fitted.Yes I have both...
I have both as well. Are they not standard?
May I ask a favour? when you're in your van next, would you mind taking a pic of the aux battery and the shelf above it? Many thanks...Yes I have both...
Yes, no problem, will do tomorrowMay I ask a favour? when you're in your van next, would you mind taking a pic of the aux battery and the shelf above it? Many thanks...
Here you go, battery area. That’s a toaster btw. I noticed your control panel has more info than mine. Think this maybe your energy pack info? See my panel.
Also looked for an additional battery under floor. Just jack and tools area in mine. Least I know where they are now
Thank you.
Yes, first thing I did was tie the curtain back too. Found a jack under the floor also. is there any electrical boxes behind your toaster? This is a picture of my battery box and charging system.
Exactly the same...
I haven’t got that. All my heating is through the Truma unit, diesel only. Do you have electric heating?
Have you got this info knwldgeseker?
I don't have the ambient lighting, so no light in the cubby in my vehicle.
What I did find was we couldn't turn off the middle light without turning off all the lights. This was just because the washroom light switch (behind cabinet) was on. Once turned off, you can have all usbs working with lights off. I think this is your problem.
Yes, the colour change if off, there is also an panel light with switch above sink and a magnet light activated when the cupboard door is open, all off.To confirm, you can have all lights off and have usbs on. Reading lights turn on by touching the back of them. The way to do it is have the reading lights on, then go round turning everything else off. You have everything off and readers still on, bingo!
Jeez, things you should not need to do with a new vehicle!Worked it out!
been wired wrong. The feed for the ambient light has been crossed with the reading lamp. Swapped them over and all working now.
Thank
