Wind deflectors are good if you are with the vehicle., Security.Just looking at ventilation. In the cab looking at wind deflectors or the Brandrup driver and passenger ventilation any thoughts on which is better ? Also how is clear plastic cover for the side window
I also have both and find very helpful driving (deflectors) and camping (both).Wind deflectors are good if you are with the vehicle., Security.
The Brandrup./ Reimo window vents are good for ventilation when the vehicle is unattended on campsite.
I have both. Deflectors for overnight and vents for extended stays
Yes. I have Dubreflecta;s fitted and use the Ventilation grills at same time.I was wondering if you could use both, so the brandrup ones will work with the wind deflectors do even when you put the clips into the window frames
