D
Dan
- Messages
- 102
- Vehicle
- T6 Cali On Order
Haldex has nothing to do with the rear axle. Amarok is completely different, has the system larger Audis have been equipped with since the 1980's, Torsen.
I didn't say it did. Haldex is the system that distributes power between the front and rear axles.
The Amarok is available in two versions - selectable 4wd (using a mechanical centre diff lock) and permanent (as you say using the torsen system) I'd pick the selectable if buying that type of vehicle.
