SSMPJStew
- Messages
- 3
Worked well for me too nearly a year later.
Thank you.
Thank you.
No water in my kitchen tap..!
5 amp fuse is ok.
Removed the pump and hooked it up to a 12 v supply and it worked. Water is coming out of the tap.
Measured the bare cabels coming from the tap (with tap started)(without the pump connected) and read 12 volt current.
Reconnected everything again (cabels from tap connected to the pump), but the pump isn't working. Now I measure only 0,8 volt...! The tap makes a click when I turn it on.
What is going on here?
(I have noticed the last months that the tap water is loosing pressure...and now no water at all).
Could be chalk or is it limescale ( google) in the tap or tubes
Seems you are able to open it all up and DIY , just buy a new pump , not that big coast .
If your Cali a 2006 as i can see it has had 10 years ....
But the pump is working so no point of replacing that
So you think there's an electric failure...
But if the pump is old and worn could be it not builds enough pressure
5 amp fuse is ok.
Thank you for letting us know the outcome.Yes, it was the micro switch in the tap. Just dismounted the tap, opened it (pull the small lever straight out) cleaned it out a bit and then everything worked as normal
The micro switch is quite small and if you do this make sure to sit at a table with good light.
Like someone said, you can shortcut the connection to the tap under the sink to bypass the micro switch and start the water pump. If it do start, then it's the micro switch.
Thank you everybody
Great post and very informative, as a retailer of used California's we often have to deal with "no water," in our preparation and while under warranty. Usually 1 0f 4 items, fuse, micro switch in tap or most commonly the submersible pump has been left running and over heated. We recently had this issue for a customer in Bristol area under our warranty. The customer tried to have a go at fixing but was struggling so we suggested a VW Van Centre, thinking with their fault finding and "Master Tech," one hour or so and a pump and all sorted. VW Van Centre Swindon charged us £267 to deal with this, 2.9 hours labour after discount. We've queried it as we feel this is quite excessive and had an explanation that they only charged us 2.9 hours and the "Master Tech" actually clocked on for 3.49 hours. To fix a blown fuse and change a submersible water pump?? In contrast one of our customers had the same issue, took it to SMG Cowfold and was charged £53.64. What a difference, how difficult can a 12v water system be to fault find and repair. Needless to say we will reimburse our customer but do feel disappointed with VW Swindon Van Centre and their response to our query as I wouldn't feel comfortable charging this amount for a relatively simple fix. What do you think?
