monster-mash
Just running some tests today following a cali kitchen (2008/9) fit, everything is wired the same as a Cali so everything is opperated via the camping control unit. I also replaced my existing Leisure battery a 75amp/hour just the one with a beefier 100amp AGM as we have no heater just the roof and kitchen.
Problem is when I was hooked up to mains the CCU display switches from Battery to fork plug emblem on the also it showed battery at 40% charge also 5amps which held pretty much unchanged for hours. Unfortunatly the onboard supply unit got fairly hot as did the battery after a while so i switched the lot off.
I swapped back to my existing battery which when turned back on done what i would of expected a initial few Amps then reduced and held a steady 0.6amp charged rate. Onboard charger remained cool to warm and the battery cold, the onboard charger outputs to the starter battery also and this function is all opperating as normal.
My questions are
"does anyone know how warm, cool etc does there cherger unit get"
"Charge rate average on the camper Control Unit, i assume you leave it plgged in for the duration of your stay"
" anything mentione in ther handbook relating Engine being started when being hooked up, reason i mention this is if there are any implications with the output from the onboard charger meeting the Alernater (genarater) output, i assume the onboard charger is protected but its worth the ask.
Sorry for all the questions I think the new battery is Kapputt
My questions are
